I, like many, love the LGB F7 diesels, but the front truck position really bothers me, its to far forward and throws off the balanced look of the prototype.I wanted to document this modification here for beginners that might be considering the LGB F7 but like me, are bothered that the front truck sits to close to the pilot skirt and needs moved rearward toward the fuel tank to “look” more correct. When you look at the pics, the folks at LGB knew this might be an issue as there are 2 unused factory screw holes to move the truck bolster rearward. But when you do this, you have to body mount the front coupler. I reuse the coupler mount but remove the linkage plate and centering spring from the front truck. I then drill a small hole thru it and the pilot frame and put a single LGB philips head screw thru it to hold the mount to the frame. I use LGB knuckles as they behave the best on my tight radius curves. I then remount the front truck using the rear most holes for the two bolster mounting screws. A simple, easy peasy, modification that really improves the look of a fine model.
Here is a pic with the front truck hanging off to one side, you can see the original coupler mount in its position, but screwed to the frame of the engine. You can also see the two pairs of bolster mounting holes in the frame, front set is the stock position, the rear pair is where I move the bolster to once I mount the coupler to the locomotive’s frame. I will take a nice side shot here in a little bit on my layout.
