I took a chance on a boxcar with a undisclosed sound system in it and it turns out it is a LGB 65004 euro diesel module. I looked up instructions on line, scrolled to the English part and didn’t have my questions answered. The original owner has this mounted in a euro boxcar with electric pickups to the wheels. There is also a 9volt battery hookup I’m assuming to provide sound when the train is standing. The wiring is pretty simple 2 wires connect both axles, a black and red wire goes from each axle to the sound unit and the 9volt leads also connects to these red and black wires.
I put this unit on a test track and as throttle/voltage is applied the sound gets louder and faster. If the battery is attached the track voltage doesn’t work. Occasionally a euro horn sounds but this cannot be predicted at any voltage.
From the online directions it takes the LGB MTS system to unlock other sounds from this unit. I don’t care to do that. What I would like to do is stick this unit in a USAT diesel. Any tips on how to do this besides hooking up to the wires that pick up the power off track? Can I get the sound to work off the battery and the track voltage?
Thanks for the comments.
