Can the chuff rate be adjusted on the 65000 steam module ?
Manual says CV 64 for chuff rate.
Thanks dan, but I am running analog. The sound module is fitted in a trailing car, if that makes a difference.
Would anyone know who sells Massoth products in the states ?
Hi Dan, contact Mohammad at All About LGB. He stocks the complete line of Massoth. https://www.allaboutlgb.com/
Thanks Don. Message sent.
Dan Padova - Did you get your LGB Sound Module chuff rate adjusted. You need either a DCC system to do so, or, a Massoth PC Interface Module that’s only powered by a 2 Amp DC power suipply. Also, since you’re running Analog power, the LGB 65011 Power Storage Unit that plugs into your LGB Sound Module helps to operate the sounds better which needs a minimum of 6 volts to work. So the Power Storage Unit powers the sound unit a lower voltage (lower loco speed) and when your loco comes to a stop, it powers the sound unit for about 25 seconds. I sell the LGB 65011 on my Website; I also sell Massoth DCC components and am an Authorized LGB Service Center if you need any assistance. Below is a photo of an installation I completed for a customer of an LGB 65001 American Steam Sound Module into his LGB Mogul Tender. Website: https://www.olddominionrailways.com/
