I am replacing the brushes on myLGB 0-4-0 but I don’t know what I am doing.
I spent an hour getting three brushes in but if I try to put in the fourth one I think they all will spring out.
I need help. How am I supposed to do it?
Once you get the spring and brush in the hole, if the spring is keeping the brush out of the hole use something thin like a knife blade and push the assy in and while holding in replace the correct drive wheel, once the wheel is over the brush you can slide your knife out and secure the wheel
A small piece of cardboard, the diameter of a wheel, then cut a slot in it to go around the axle, tape in place… get the axles in, then remove cardboard.
