1st car?
1954 VW bug, oval window, periscope tail-lights, semaphore indicators in the door pillars. 1136cc of extreme non-grunt.
But…
18 months later…
1954 VW bug, oval window, latest model (1964) tail lights & front blinkers on the top of the mudguards (fenders for Yanks),
VW Kombi 1500cc engine bored to 1830cc, heads shaved, ported, polished, 2 twin choke Webers, full extractors, 3/4 race cam, Kombi clutch with twin h/d plates, doubled valve springs, swing axle converted to non-swing using Model T front spring between rear bottom shocker mounts, front brakes converted to Porsche discs, suspension lowered at front by resetting torsion bar, at rear by having springs & shocks reset, gearbox swapped for 1962 model with synchro on 1st gear, wheels changed from 15" to Holden (GM)13" rims, widened to 7", shod with Michelin Rallys, dash enhanced with tacho, fuel gauge, oil temp, oil pressure, head temp & Halda Rally trip computer (they called it a computer but it was all mechanical, just a fancy odometer & clocks combo).
Interior? Stripped, replaced with 2 racing buckets from a Porsche 911, rudimentary roll cage, 3-point seat belts (race harnesses were then just for pussies!), gear shift moved back on the tunnel 8 inches, separate left & right hand brake levers, all heater baffles thrown in the garbage.
5 Cessna landing lights fitted to front rack,relayed from 2nd 6volt battery under where the back seat used to be. Also 1 mounted on the rear for backup.
Drove competitively for VW Club South Australia in numerous rallies, including the 66 Great Southern Rally which in its day was equivalent to the current World Rally Series. Came 7th in class, not bad for a pair of 18 year olds!
I’d give my left nut to have another '54 but this time I’d just restore it to its gutless original
