Is there any interest in a circuit that will dim LED’s that are too bright to a level appropriate for the use you need. LED’s have gotten so efficient they are way to bright for a lot of applications in Garden Railroads.
No resistors calculations needed, just connect, uses a 5 turn miniature potentiometer to fine tune the light output.
I have designed such a device but was wondering if there is a need for it.
Specifications:
Voltage : 7 to 32 Volts DC (DC, DCC, Battery)
Maximum Current: 15 ma (optional 20ma) Output Short Circuit protected
Minimum Current: .001 ma
Types of LED circuits : Single, series, strip, internal resistor, assembled devices from other manufacturers.
Colors : All Colors supported (1.8-4.0 volts).
Application: Head Lights, Rear Lights, Cabin, Caboose, Marker, etc
Size: .4 x .25 x .15 inches
