Oh, I appreciate all the feedback. But yes, please remember that I am a bonafide member of the “battery mafia” myself. I’m asking questions about track power because I’ve NEVER USED IT OUTDOORS. I only know battery power and aluminum track, and I know it works fine for most everybody around here.
But this is a special case. I have a lot of children visiting, and I want something that just moves itself back and forth periodically, to give them the idea that something’s happening. The idea is to have a little mine locomotive shunting a little tipper car back and forth between the mine and the tipple, loaded on the way from the mine to the tipple, dumping automatically into the tipple, and returning empty to the mine. I’ve got the unloading down, but the loading is still in the design phase. Anyway, I have a lot of experience with this sort of shortline back-and-forth operation, INDOORS, under both track power and battery power. But the track power experience was very unsatifactory, due, I believe, to the aluminum track I was using. That stuff just could not be kept clean enough, INDOORS, to conduct electricity reliably. I would never try it outdoors.
I’m aware that I could do it with an onboard battery and reverser/throttle unit, such as Tony’s excellent RCS Boomerang system. But then I have to use a trail car, due to the small size of the locomotive and rolling stock. And I don’t want to use a trail car…why is that mine loco hauling that box car or tank car or loaded ore car back and forth but not delivering something somewhere? It doesn’t make sense. Or I could use very small batteries, but they might run down too quickly. So…why not run it off a little motorcycle battery hidden inside the mine building, or a 12V feeder from the house? Track power, see? Hence my question here.
