Someone in our area came up with a nice idea called the “Urban Workshop.” They offer the public access to any of the new high tech tools and provide the classes for the people to learn how to use them.
I’m talking HAAS CNC mill, lathe, welders, Auto tools/lift, laser cutter/etcher, PROFESSIONAL 3-D printer…, the works!
I will be checking this out this week for sure!
Listing of tools offered for use:
Abrasives
Disk and belt sanders
Two large cabinet sand blaster
Wire wheel, pedestal mounted
Arts and Crafts
Vinyl cutter, computer controlled by Roland
Soldering irons and wood burning kits
Assembly Work Area
10 Large work tables with vises
Compressed air and electricity at each table
Bin wall for sharing parts and materials
Great for work groups, club meetings, or events
Automotive
Floor jacks and jack stands
Large assortment of specialty automotive tools
Air tools
Alignment tools
Diagnostic computer equipment and scanners
Shock Dyno, Rohrig
Battery charger
Waste oil and coolant collection
Ceramics and Glass
Skutt kiln GM1018 (24″ x 24″)
Computer Lab
Dell Workstations with large monitors
HP Color printers
HP Large Format color printer with roll feed
Fax, scan and color copier
Engineering software (Fusion 360 & Solidworks)
Design and photo editing software (Illustrator, Photoshop, Corel Draw)
Video editing software
CNC programming software (Aspire & HSMWorks)
Internet access / WIFI
Co-working space and Conference Room
Tables and chairs for work, meetings and events
55″ Flat screen TV
Overhead projector
Refrigerator and freezer
Bose public address system
Electronics Lab
National Instruments Virtual Bench and MyRio
Soldering, resoldering, and fume extraction equipment
Wide assortment of crimp and connector termination tools
Amscope binocular microscope for board work
Multi-meters
Oscilloscopes
Signal generators
DC power supplies
Fabrication
Chop and cold saws
Drill press
Vertical Band Saws
Tubing Bender
Fabrics
Juki single needle sewing machine (Industrial)
Juki walking foot sewing machine (Industrial)
Juki Overlock Machine, Serger (Coming soon)
Embroidery machine, computer controlled (Coming Soon)
Cutting and layout Table
Four color Silk screen machine
Hand Tools
Large assortment of hand and cordless power tools
Layout and Measuring Equipment
Romer CMM arm, Infinite model, 3 meter volume
Large Surface plate
Height gauges
Calipers, digital and dial
Micrometers, digital and dial
Machining
Bridgeport mill with Digital read out and tooling
Lathe, Large metal lathe with tooling
CNC Vertical Mill, Haas TM-2P with tooling – Brand new
Plastics
Belovac BV Class C 24″ x 48″ Vacuum former
Morgan Industries injection molder, Model G-100T
Vacuum Pump and resin traps for composite vacuum bagging
Carbon fiber and fiberglass lay up area
Heat strip bender
Prototyping
3D Printer, Dimension Elite FDM, ABS plastic, .007″ resolution
Epilog Helix 50 watt laser etcher with rotary attachement
Epilog Zing laser etcher, 40 watt
Pressure vessel, 55 Gal, 24″ diameter, heated for making silicone molded parts
Sheet Metal
Box and pan brake
Jump Shear, 48″ wide
Mittler Brother bead roller
Planishing hammer
Beverly Shear
Corner notcher (Coming soon)
Misc hand shears and tools
English wheel (coming soon)
Rotary turret punch (coming soon)
Slip roll, powered, (coming soon)
Surface and finishing
Aluminum anodizing
Outdoor Spray painting area with part rack
Powder coating station and oven (Coming soon)
Welding
Miller Welder, TIG (2x)
Miller Welder, MIG (2x)
Chicago Electric Welder, Spot
Oxygen and acetylene torches
Plasma cutter, hand held (coming soon)
Plasma cutter, CNC, 4′ x 8′ (coming soon)
Wood Working (all new equipment from Laguna Tool)
CNC Wood router, Laguna Smartshop 1, 4′ x 8′ bed
Table saw
Compound miter saw, sliding
Table router
Shaper
Mortiser
Band saw
Belt/disc sander
Scroll Saw
Drill press
Image on the right is also very cool!
.jpg)
