Testing out the newly approved leaf blower. I was using a 12 volt closed cell battery and cut the caboose body down to fit it. The battery died on me so I ended up getting a 18volt 2000mah battery that I can use in my Dewalt drill and recharge with the dewalt charger. The battery was larger so I had to remodel the base where it sits to lower it and cut out the back of the caboose which required something to be extended back there so I used some scraps from the parts bin and built a fuel tank.
I also added weight to the front truck and put in a screw to limit its side to side movement.
Still tinkering but I think it is working pretty good now.
