LBG 20211 motor
Hello anyone know where i can find a exploded parts view for an LBG 20211 loco? I need a new motor and need the part #. many on line supliers show a picture of the motor but i cant tell if its a short shaft or long and they dont give any dimentions .My motor has no part # on it , it only says Buhler Thanks for the help Tony
Anthony,
the motor that you need is the short shaft #62201. This is the later version with ball bearing housing. The long shaft motor is obvious in that there is at least 0.5 inches between the pinion and the motor housing at each end. The Stainz type motor (short shaft) has very little distance between the pinion and the housing at either end. The long shaft version is used generally on the 2-6-0 Mogul.
thankyou for the reply!!!
And remove the little ball bearings at the ends of the motor if they are still there.
Newer motors do not need these ‘thrust’ bearings.
