I was looking at some old photos of standard gauge rolling stock in the 40s and noticing how varied it was. I did some research, and found out there were USRA double sheated boxcars, USRA single sheathed car, and, as in this picture, converted reefers. But I don’t have the skills of Bruce, or Bart, or Ray, or a whole bunch of people. I wanted to make use of what I already had and get some of that same look. So I decided to see if I could approximate some of it, and set out of make a Double Sheathed wood side, steel end boxcar out of an old Aristo 40 foot steel boxcar Scraped the detail off the sides:
Bought some micromark scribed siding, 1/16th thick. Turned out to be too deep
So I planed it down using a nifty tool, the Wagner “safe-T-Planer,” which chucks in a drill press.
OK! I cut the panels to fit the sides, and thought about using the Aristo Youngstown door. Sometimes the double-sheathed boxcars had steel doors
But more often they had wood. So I fabricated a couple doors out of the siding, and used parts from the ice hatch on a reefer to simulate door hardware. And added coffee stirrers on the roofwalk, and threw a hasty coat of primer on it.
I’ll probably badge it for Lehigh Valley. It ought to have a brake wheel above the roof line, probably, and I’ll streak the roof gray, I think.
You has me sympathies!
