Ok finally got this on here. I want all thoughts, ideas, what would you change, etc. Right now this is a ground level plan, whole yard size is 66 x46 with the low wall at the top (north ) about 3 feet from the actual block wall 18" above the actual rest of yard. My thoughts are long, 15-20 car trains with minimum 10" curves, main one being by the pool pump on the right side of yard. Az landscaping, 3/4" rocks everywhere except grass and pool decking. Hard clay soil so scraping rock away is probably ok for sub road bed, then building up actual road bed with crusher fines or grit.
The loop on the left is about 15’ from house to wall and flat, but loop on right will be the 10’ curve and it will be where trains go up or down from lower to upper level, so I have to figure out best way to ease the climb or decent, having the pool pump there poses a problem, access to pump etc, so maybe a tunnel to get to upper level , or a deep cut will be needed.
^^ here is the view from the house looking kind of north west.^^ most of the landscaping is subject to change, except the trees
this gives a good idea of the elevation change needed on the pool side. The 3ft block wall hiding the pump is just stacked, so it can and might be removed or altered as needed. On the left side the elevation change will be on straight track so not as problematic. Oh yes, and good eyes will catch a problem with the pool, this is calllled a rolled bond bead, and the pool company has since found out it will delaminate like it has, several times. Don’t get me started. Anyway I welcome your thoughts… go!
Yard is about 22ft from patio up to north (top) wall, the 46ft is long side yard included
