Just a little item to share with the gang.
This is a 7/8 scale passenger truck built from NENG plans that come in GR. I made a few changes to the assembly, instead of cutting out a milion pieces of thin plywood, I did it once, assembeled and detailed the piece, made a mold, and cast it in Alumilite! Instead of styrene for the straps I used brass strip, in the photo the black part is the Alumilite, ceptin for the springs which is just wire wrapped around a dowel and glued in place.
One down…5 to go…And then theres tomorrow…
