I’m interested in getting a laser cutter, and am looking at the Chinese units on Ebay / Amazon. My thanks to Dave Bodnar for his great seminar at ECLSTS last year, and article about it on trainelectronics.com.
I need to be able to cut up to 22-24" long parts, so the 500x700mm units are attractive (see below). I’m not going to be able to get an Epilog or Full Spectrum, because I need to stay near $2k.
I’ve heard bad things about the units, such as the laser tube going not lasting at all, the software being poor, bad mother boards, etc. But, I’ve heard good things as well. So, if you have some insights, I’d be grateful. Here goes with the questions.
Vendors / manufacturers: any that need to be really avoided?
Reviews: With all these units being sold, why the absence of Ebay reviews?
Support: I don’t see any email addresses, support web sites or forums specific to the manufacturers of these (except one: hflaser.com). Anyone had successful support contact, and if so, with whom? Anyone found a helpful forum or two?
Control: any opinions on what software to look for / avoid? I’ll be using DXF files. Some cite AutoCad output or DXF, and that’s a gotta-have for me.
Power: I need to cut up to 1/4" plywood and acrylic. Is 50W good enough?
Functionality: Some units mention only engraving, some only cutting, some both (which I’d like). Is there actually a diff? Do I need to make sure I get a unit that says it will do both?
Is one able to etch deeply enough into acrylic material to emulate a joint between boards (after painting)? Is that sort of a matter on high high the power setting is?
Motorized up / down (vs manual): What’s the purpose? Is that a sort of auto-adjust for changing material thicknesses?
Sheet size: When they cite a working size (say, 500x300mm), is that the size of material you can shove in, or what the laser can actually cut to?
Installation: are these the kind of thing you can stand on end and maneuver with a furniture dolly, with a couple people?
Here’s the reason I’d like to get a 700x500mm unit. The main purpose of this would be for large mining structures (served by the V&T) and other buildings on the layout. I did an example pattern set using 300x500 and then 500x700.
I learned from this exercise that, for this particular structure at least,
- The larger unit would save gobs of time (less than half the effort) in material pre-cutting and machine loading
- Would require far fewer material splices in the structures
- Slight savings on material, due to joint avoidance inefficiencies w/ the smaller unit
Sorry for the long-windedness, and many thanks for any pointers & opinions.
Best,
===>Cliffy
I also appreciate your advice to get the cutting done by others. I haven’t found anyone local to take it on though, after several searches. My mining structures alone will eventually involve around 16 4x8 sheets of acrylic, so that would be many thousands in cutting fees I’d expect (over several years). So, that’s why I’m considering the lower-quality cutter.
