Yep, they sent me 50hz / 240v. And a US seller! I sent them a fat not-happy-gram, and they fully refunded me. The new one (NOT from that first dope) seems to be running fine.
By “running fine” I mean on 110vac / 60hz (which it’s labeled for), and with the outlet plumbed right back to the inlet. The chiller has a 9L internal reservoir, but I was expecting to have a tub of water (like I’ve seen in many installations, where they are using a pump, not a chiller).
So I set it up like that, with the chiller reservoir filled, its outlet hose dumping into the half-full tub, and the inlet hose drawing from the tub. But after switching it on, the chiller just emptied its internal reservoir, and didn’t suck water any back in. So it seems like it’s designed for a closed-loop system, not open with an external reservoir.
Once I connected the outlet to the inlet, it ran fine, chilling the water from 25c to 22c. So the question I asked the vendor is whether this is the intended setup, or is their an inlet pump that’s not working.
This “chiller” doesn’t use refrigeration, only a fan and radiator I think. Also, there’s no setpoint adjustment; it’s meant for a 60-80W laser, and I guess you turn it on and hope for the best. But I asked the vendor about setting the temp as well.
I’d like to add a temp probe & meter, also an ammeter, per the advice of Dave Bodnar & others.
