In terms of the voltage, figure out how fast you expect your trains to run. If you have a power supply now, and your trains run plenty fast with that, then that’s a good ballpark for the voltage you would “need” for your DCC power. For example, I model early 20th century narrow gauge, so I don’t need voltages in excess of 15 volts to reach “prototypical” speeds for my trains. Contrast that with Greg (above), who runs modern mainline stuff. He needs 24 volts to get his trains to run prototypically fast. Different railroads = different requirements. While 24 volts is often used as the “norm” for large scale DCC track voltage, it’s not mandatory. I’ve got an MRC system that gives me 15 volts to the track, and a Piko system that gives me 20 volts. There’s no difference in performance in terms of functions (sound, motor control, lights, etc.); they just run a bit faster at 20 volts. For my personal situation, I’d find a 19-volt power supply to be perfectly acceptable.
Having said that, while you may find your 19 volts to be sufficient, the 7.7 amps may be a little low depending on your power requirements. (I’d definitely shy away from the 4.62 amp supply.) How many locos are you looking to run at any one time, and how much current would they draw? I would consider 7.7 amps good for two “average” trains. Usually, 10 amps is considered the practical minimum for a power supply, but if you’re running shorter trains, I’d think 7.7 amps would be good for two or three locomotives without issue.
From a practical standpoint, the oft-recommended power supply for large scale DCC is a MeanWell 24v/10a unit. That’ll run you in the neighborhood of $50 or so. (If you look on Greg’s site, I’m sure he’s got a specific model number somewhere.) Look at what your needs are, compare the prices of the Dell units vs. the MeanWell, and go from there. At the worst, you save a few bucks buying the Dell power supply right now, find that down the road it’s a little underpowered for your needs, then swap it out with a more powerful unit. You’re not spending a ton of money on the Dell power supply, and it’ll be easy enough to repurpose it elsewhere as maybe a workbench power supply or for lights and accessories for the railroad. It’s a safe gamble to make if you think it will work right out of the gate for your needs.
