what material did you use for your ladder rails? (trex, tufboard, trimplank, etc.)
Trex
what is the dimension of the material and was it cut or manufactured to that size or did you rip it down from larger stock?
Used 1 in by 12 in plank from Lowes, ripped in half, cut to about 2 3/4 in wide
what material did you use for the ladder rungs/spacers? (PT lumber, etc.)
ditto on the dimensions,etc.
trex
what is the total width of your ladder?
about 3 1/4 in wide
what material did you use for your uprights? (pvc pipe, PT lumber, etc.)
PVC, but learned that underground costs half
how far apart are your supports and spacers?
2-2 1/2 ft apart
how tall is your ladder track?
from 4 in to 3 ft high
is it filled in underneath (if so with what?) or free standing?
free standing
how much of your support did you bury? and what did you use to set it? (concrete, existing soil, gravel, etc.)
2 ft in the ground, pounded it in the ground
fasteners used? (deck screws, etc. sizes?)
I drilled all the way through Trex and PVC pipe, used stainless 1/4 in bolts and nuts, nuts and bolts
Additional comments -
Pro/cons, likes/dislikes for your system
what would you do different?
Very easy to put up once you have PVC in ground
tom h
