Someone may have made a post about this water base paint One problem working with foam has been getting the right paint. Most spray can paints will ruin foam , just dissolve the foam. Leaving a melted mess. H2O paint is water base paint in a spray can. Over spray clean up with soap and water up to 20 minutes after you spray. No waiting for a second, third coat of paint. 15 minutes drying time. Tried it on the tunnel portal and some buildings all made with unpainted blue foam. Worked great.
Now I have to see if I can use acrylic and acrylic latex paints to finish them. At present I saw only eight different colors on the shelf. The only place I could find H2O paint was at Wal-Mart. I’m using a light tan color as a base color in the pictures. Yogi Bellaire, ohio
