Kristi Edington
Hi Folks… Rodney just called to share that Kristi will be flown to Mayo in Rochchester, MN via Air Ambulance tomorrow, June 25…
Remember them in prayer and for great wisdom for the doctors to find the cause and cure for the problem.
Definitely!
Best wishes that Mayo will find the problem and a speedy recovery. Will be thinking of the Edington Family.
Ditto......Hope all turns out for the best!
Best wishes for all…
Rodney & Kristi will be in our prayers.
Prayers and well wishes to the Edington family.
Trains are nothing compared to our loved ones.
We are hoping for the best. The Mayo is 2 hours away…Let us know if you need anything!
You guys will be in our prayers as well. Good luck.
Hoping and praying for the best.
Your family will be in our prayers.
Our prayers and best wishes for a full recovery.
Bob C.
Thank you Stan for your help
I just got home from KU Med so I can get stuff packed up to take up there. I’m taking 2 of Doug’s (Bronson) coach kits and one of Phil’s 40 foot refer kits to work on.
Last fall we found out the she has a blood bacteria that only about 1 or 2 cases a year is found. They installed a PIC line in left arm and started her on IV antibiotics. In the middle of April the line clotted and found the clot was from just above her elbow to up past her shoulder. They took the PIC line out and installed a central line into her chest and was sent home after about 10 days. She was home for 6 days and the central line clotted. After a 14 day stay they sent her home again. 3 weeks ago she went to see her Cardiologist and found the clot in her chest was getting larger and admitted her to the hospital again . They have went in 4 times and put stints in and a jet of some kind. They have ran a lot of test for the clotting issue and still no answers. Doctors has warned us that as soon as they get the clotting solved that she will more than likely have to under go surgery to replace to a lot of the veins going to her heart.
Thank you putting her in your prayers.
Mark,
I’ll might send you a PM and maybe we can get together while I’m up there.
Rodney
You’ll be in our prayers.
May your God be smiling upon you, and our prayers answered.
Thoughts and prayers from the tacs here in yUK.
tac and famb
Rodney. Our thoughts are with you both…
Yikes, scary stuff. Our prayers as well.
Add our thoughts and prayers that all comes out for the best.
Rodney - You and Kristi will be in our thoughts.
