same scene with external light: (i put the Bachmann engineer in the scene, to give you a measure for the dimensions)
(http://kormsen.info/specials/kerosenelamp05.JPG)
the most difficult part: cutting the cylinder. i destroyed the first bottle. the glas is very thin and my cutting disk has a whobble… i’ll have to ask at the hospital for smaller bottles. at the veterinary they had only this bigger type.
(http://kormsen.info/specials/kerosenelamp01.JPG)
for the tank i found these buttons(upper right) they are meant to covered with cloth and then to be pressed together. then i searched something for the “lamp-head”. an old .22 shell, cut to length was the answer. as i do not have a vise, i could not drill these tiny things. so i hammered a nail through them. (not very centric, i’m afraid)
(http://kormsen.info/specials/kerosenelamp02.JPG)
i took a grain of rice lamp from a christmas curtain, glued it into the shell (all glueing with the standard UHU glue), glued the shell into the upper part of the tank, filled everything with glue, put the lower tankhalfon the glue and forgot to pass the lightbulb with a yellow or orange marker (i had a hard night at our Oktoberfest) then i glued everything on a “tabletop” andafter the table got legs to hide the cables, i glued the cylinder on top of everything. if i discount the waiting for drying glue at the various steps, i put less than 20 minutes in it.
(http://kormsen.info/specials/kerosenelamp03.JPG)
