I’m getting down to the short list of mechanical features, starting today with the cab steps. They sort of wrap onto the brass stirrups.
Then finished the stack, with putty (sanded and inked black) over the BB’s. Also the final cap screen, 2 layers of black aluminum window screen.
I worked out what I wanted to do on the roof. No one knows (yet) what the Joe D. had as an original roof – but this will probably change with the research coming this spring. However, it sure has roof on it in the museum now, and that’s good enough for me.
That roof is 2’ square bare metal sheets, heavily tarnished. It was put on as a cosmetic surface, and doesn’t necessarily reflect a particular historical practice. So, using a scrap cab, I used 1" square self-adhesive copper sheet, overlapped and dimpled for nails.
I considered using “real” brass nails and drilled-in holes, but after 10 minutes said screw that crap. They’d mess up the interior ceiling; and this isn’t the historical roof. So I dimpled it (with an awl, just by eyeball), seemed fine. After that I tried 6 different acids for aging.
The section on the far left has the acid I’ll probably use. Nothing dramatic, but it sure knocks down the sheen nicely.
I think I’ll try an easier method for the sheet, which should produce the same results: crisscross 1/8" copper strips, then dimpling, then a single sheet over the whole thing, burnished in. [Edit: naah, the jagged joints look better.]
I laid out and lasered all the window panes and interior frames. Also a little marking jig for the copper strips.
Lastly, I started on the sand pipes, bending & cutting the 1/16" rod. These will need a couple new brackets between the drivers, which just printed. More on those tomorrow, Lord willing, and also final work with the boiler+jacket.
