I hope that one of our JMRI experts might have a suggestion for me regarding this situation. I’ve tried to distill it down to the pertinent facts. If you have the patience to read through it then I would appreciate your thoughts. Here goes:
Location is a turnaround point on the schedule.
Location has one yard track with a capacity of nine boxcars and one spur track with a capacity of four boxcars.
Spur track holds three empty boxcars
Train arrives with four loaded boxcars
Train sets out three loaded boxcars on yard track
Train sets out one loaded boxcar on spur track
Since this is a “turn” train, the train picks up the three empty box cars on spur track, leaving one loaded boxcar on the spur track and three loaded boxcars on the yard track
My goal is to move the three loaded boxcars from the yard track to the spur track thereby clearing the yard track completely.
I set up a “switch” schedule and “train” to work the yard. It successfully moved the three loaded boxcars to the spur track, but it also moved the loaded boxcar already on the spur track to the yard track and changed its load to “empty”.
Is there a way to tell JMRI to ignore the boxcar already on the spur so I can place all four boxcars on it?
Thanks for your help!
