So in all the years I’ve owned stuff I’ve never owned anything long enough to wear it out.
As an aside that probably says something about me being a little mal-adjusted in some way or another
So hear I am with a well used NW2 that may need new motor blocks. I know it’s not electrical as I run battery and all connections are fine. There are no split gears that have not been dealt with. It’s lubed. The little thrust bearings are not too loose or too tight so I’m thinking the little cheap motor has seen better days. Do I just spring for new motor blocks?? C.Ro and company are only 20 minutes away. What say you. I have 5 of these so Aristo parts are not an options. After market???
