Gary,
I like the look of that caboose track!   Beautiful looking switches as well - and just about the configuration I’ll be doing.   Good looking trackwork all around.   Now, is there a handy run  around to get the caboose in there?
Ric,
I have a recipe for the ties and rail lengths.   I use   3/8" x 1/2" cedar that I get from Bob at Garden Texture.   I know, I could cut my own, but there’s already way too much dust in my workshop.   I just cut them to length.   Up until now, I was cutting 2 7" pieces for the switch stands, four 5 3/4",  three 5 1/4", three 4 3/4", and three 4 1/4".   Also some number of 4" pieces to match the length of the AMS ties.     I cut these to length from the 24" pieces I get from Bob Kelly.
For the rails, I cut the following, based upon measurements from a Llagas Creek #6 switch:
26 3/8"  for the long straight.
26 3/4" for the long curve.   Both of these pieces have a 2 1/2" slot ground in them to allow for the points to fit closely.  Yes, I know that’s not how the prototype did it.  However, they work quite well, which is what really counts, no?    You have to visualize a switch to understand what I mean by long straight and curve…
10 7/8" for the short curve
10 3/4" for the short straight
4" for the straight after the frogs
4 1/2" for the straight piece on the curve
two 4" guard rails
Points are 4 3/4" long but are really cut to fit.  I try to make sure that they overlap a tie on the end, so they don’t dip at all.   A stip of brass connects them.
Hmm…does that make sense at all?  It makes sense to me…sort of…  I try to build a set of directions for stuff I build more than one of.   That way I can replicate my results later when I have to build another.
Now, having said all that, I’m changing the ties a bit for this next batch of switches.   I found a PDF file of some H0n3 templates, and using Scale Print I enlarged them to 1:20.   They print out on four pieces of paper - I taped them together and they will require a few more ties than the eleven switches I’ve made to date using those measurements above.
Using my ready made frogs and points, I’ve found it to be fairly straight forward to make all of these switches.    Don’t get me wrong, I would have loved to just buy the darn things…but I just could not justify spending over $2,000 on switches.   Yet, I didn’t want to make them completely from scratch - although many here have done just that.   I did buy a couple of ready made for patterns.  I also bought some “kits”, to help me get started.   And, I picked up a few deals along the way.   Everything helps.
