Victor Smith said:
I think if I had the cash, I'd rather pre-order the LGB Unitah Mallet, but as I dont have the coin, if I want a Mallet I think I'll take Tim's approach and build my own, at least that way I be certain it will work right "out of the box".
Vic (or anyone interested):
No need to pre-order or wait. I have a test run only LGB Uintah #51 that I would be happy to turn into cash, and it is available to anyone ‘off my shelf.’
BTW, since it is currently a point of great concern, that LGB “Mallet” also is actually a “Meyers,” with both engines pivoted and the trailing (hook & loop) coupler truck mounted. The leading coupler is mounted to the pilot, but is a dummy.
I also dug out my two stored H0 brass articulated locomotives. Both the Little River 2-4-4-2 and the Weyerhauser / Sierra #38 2-6-6-2 are true Mallet configurations, with the rear engine firmly attached to the frame / boiler. I know the relatively tiny Little River locomotive will easily go around 18" radii, but if I remember, the Sierra 2-6-6-2 required something like 21" radius to be comfortable. Those radii would be equal to ~6’ 5" and 7’ 6" respectively in 1:20. Remember: RADIUS, not diameter.
I truly can’t imagine Bachmann producing a locomotive that would require 13’ diameter curves like the 2-4-4-2, much less the 15’ minimum diameter that the 2-6-6-2 would be happy on.
Happy RRing,
Jerry
