Hello All,
I recently bought a TCS WOW 501 sound decoder that I am installing in a Bachmann 2-6-6-2T Mallet that has Airwire and battery power. I have used TCS WOW in some of my HO models and it has worked pretty well. I am having some issues with this one:
First off, I am using it with an Airwire CONVRTR-60 and it powers up ok, but it is really quiet! I am using it with a 3 inch diameter Phoenix big sound speaker and it sounds like an HO locomotive. The master volume is turned all the way up and the previous decoder that was in this engine (a Tsunami 2 4400) sounded just fine with this speaker (I replaced it because it was too underpowered for the mallet). So I’m wondering if I need to get a different speaker or install a second speaker, or whether it’s an issue with the decoder?
Secondly, and probably more importantly, is that when I try to program CV’s on it, the Convrtr 60 completely shuts down. I tried disconnecting the WOW board and programming CV’s to nothing (exact same cv and values) and the Convrtr acted just fine. Plugged the wow board back in and boom, it shut down again when I programmed the same CVs. I factory reset both the Wow sound decoder and the Convrtr 60 and it did not solve either of the problems. So I am wondering if this is a common issue or if my board is unique in this respect?
I look forward to seeing what people have to say about this.
Trevor
