Jon Radder said:
Hi Matt -
I read that over on the Soap.  I’m not sure exactly what it means, but I’d think that the square drive on the universal shaft kind of makes it impossible to get them aligned wrong.  Perhaps they mean that the front and rear truck  universals are set up correctly in relation to each other?  I don’t know why that would make any difference.  Feel free to enlighten me
He means that the Y-shaped yokes, or Hooke joints to give them their correct name, are in the same plane, and not set at 90 degrees from each other.
I have both Accucraft Shays and have never suffered from the ‘clicking’ mentioned in these posts, but then I don’t have R1 curves to run them on either.  I think you’ll find that front-wheel drive cars ALSO click on full lock when they are starting to show signs of wear, and that, IMO, running a complex little loco like this with such pernickety and vulnerable drives may not be the best idea anyone has ever come up with - I certainly never would do so.
In the interests of science I set both mine ‘out of phase’ yesterday evening and ran them - both remained totally silent in the joint department, but then I’m running on 12 foot radius tracks.
I tried the same experiment with something slightly less expensive than my $3000 Accucraft Shay - two Meccano universal joints - and sure enough, they clicked when trying to transmit drive at almost right-angles - it’s simply a matter of trying to transmit torque at sharp angles via a flexible coupling.
The answer is - don’t.
tac the Griper
