After 4 years, it seems that Accucraft is finally shipping the EBT mikados. Problem is, I had just raided my “mikado fund” to pay for needed car repairs thinking the loco was still a year or more off. So, I’ve got to re-fill the piggy bank, which means it’s time to thin the herd. Locomotives Customized Roundhouse Live Steam 0-4-0
Built on a “Dylan” boiler/chassis. Everything but the boiler/chassis has been rebuilt, including the valve gear. Alcohol fired, Radio Control (RCS) included. Goodall Valve fitted to backhead for refilling water while under steam. Working headlight. Cab roof is removable to get to servos and Goodall Valve. Alcohol tank fills through the roof vent. The tender has a water pump, if you wanted to replace the Goodall valve with a check valve and feed the boiler that way. I found the Goodall valve just as convenient, and didn’t have to worry about leaking check valves. Asking $1600 plus shipping, and will custom paint for your railroad for a bit extra if you desire. Rolling Stock Aristo/Delton wood caboose - Union Pacific New in box $50 plus shipping I’ve also got an assortment of 1:22.5/1:24 figures in metal and some Preiser and other Plastic figures. Later, K
