TrainControl.com has some nice devices. I have a friend building an indoor HO empire, and he has bought several items there so I have had a chance to try some out. My background and most of the books/documentation I have are for HO scale electronics. While the theories are the same, the combination of larger size, more power, and weather affect the actual setup. Perhaps I need a refresher course on Ohm’s Law.
Right now I’m setting up an oval with about 75 feet of track and two sidings. I have 14 gauge wire I would like to connect in 4 places. If I run two wires to a block, and then split out to the four locations, it would take about 30 feet of wire. I just have to figure out how much power I need to supply to the track.
Jon, I switched over to the terminal ring connectors on rail clamps, which works well. I crimped the connections, but I may go back and solder them.
