I picked up a used Phoenix P5 from Bruce. It worked great when I got it. Was playing around with it on the bench yesterday and dropped it about 3 feet to the wood floor. Nothing looked damaged and it worked when I tried it, but then the next time I tried it there was no sound. I found that by putting a little twisting pressure on the C1 connector end of the board, it will boot up and start playing sound.
When it is “dead” I hook it to the computer and it’s recognized. The board I/O screen says the input is Zero volts. Once I get the board to boot, by twisting or pushing on stuff, the board I/O screen says the input is about 12 volts which is correct.
The symptoms act like a cold solder joint. All of the components are surface mount, so I’m afraid to go poking around with a soldering iron. I’ve thought of using my heat gun to warm things up, but that’s a little scary to since this is a double sided board and I don’t want to risk parts falling off the bottom.
The real problem is getting it to fail. Once it boots it will work through many power cycles. It seems the only way to get it to fail is to let is sit for a long time. If I had some cold spray I might be able to isolate the component that is not making contact.
I’m thinking my only solution is to pack it up and send it off to Phoenix for repair. Not really what I want to do, so I’m open to suggestions.
Fearing a long wait I and cost I can’t afford right now, I decided not to send the board back to Phoenix. I just went ahead and installed it in the Porter, upside down stuck to the top of the boiler with double sided tape. It has worked perfectly since. Go figure.
