What better to do on a snowy Saturday then run trains in the basement!
The day began as C.V.S.Ry. M-10 warmed up in West Willow Hill where it was tied down after yesterday’s Southbound run…
While the engine warmed, the crew used their new technology (Fire tablet) to take a look at the switch list…
Looks like we need to dig out a boxcar from McGillicuddy Supply. This will require a few moves as there is a car in the middle of the string that is staying. Here we have pulled the string and will drop 3303 on the main while we tuck 153 back in the siding…
After cutting off 3303, 153 is dropped on the siding. It will roll by gravity to it’s spot inside the building…
Then we grab 3303 drag it with us as we back through Box Tunnel headed for South Willow Hill…
Arriving at South Willow Hill (Winter home of Wall Station and Platform and the Pine Summit telegraph shack)…
Shoving into the siding for Chandler Quality Water where we have two cars to pull…
Here a hopper has already been pulled and spotted on the passing siding while the crew picks up the tank. Cars need to be pulled one at a time as there isn’t a lot of room West of the switch and we have 3 box cars on the train…
With work at Chandler finished and the tank coupled to the hopper, we need to get the balance of our returning cars on the passing siding and get car 8281 in behind car 152 to work the facing point at Willow Hill. To do this, we need to run through the switch for the Willow Hill subdivision. Using the RailPro simulator on our workshop PC, we flip the switch…
Next we will put the boxcars pulled at McGilicuddy’s on this end of the passing siding and run around the entire train…
After running around the train, the entire string was shoved toward the switch to get 8281 in the clear on the main where it can be tied on to from the other end…
Now 8281 can be spotted at Door #3 of McCown Freight Forwarding. While you weren’t looking, we pulled a flat from Door #3 and a tank from Russell Poultry at the far right side of the shot…
Finally, we head back into the passing siding to grab our train and head to Tyrone…
Once at Tyrone, due to lack of track to work on, we need to break the train into two car chunks before shoving into the arrival track at Tyrone where the 050 Crane will place them on the shelving to await their next trip…
After dropping 4 cars, the crew realized they left the tank pulled from Russel’s on the main back in South Willow Hill. No problem, the engine needs to be turned anyway, so after a quick run around the balloon track, we shoved back to BOX where we found our missing car and brought it back to Tyrone…
The wayward tank is shoved into the Tyrone Arrival track…
Where it and the remaining cars will be grabbed by the 050 Crane…
And placed on the fiddle yard shelving according to the switch list…
Finally, M-10 moves over to it’s assigned parking spot in the Kistler Engine Facility…
After which the crew retired to the lounge for a well deserved cold one!
Including stopping to take pictures, this very simple list took well over an hour to work. It’s always fun trying to figure out these moves within the limitations of the indoor division.
