I will be building an indoor G scale RR this winter when my house is built. I’ve built lots of HO scale “L girder” bench work and I’m wondering if the same system will work for G scale. Maybe the wood would need to be larger … any ideas ? thanks
Norm since you can walk on the L-girder bench work it should be fine for what ever you put on it. I used it when I first went to G
Hi Norm,
I guess it depends what size lumber you used for your bench work.
The last indoor bench work I built for HO years ago, I used 2x4’s.
Which I would think would be plenty for G.
Did you have any of the flooding your way?
I’d build it strong enough to hold yourself and then not worry about it.
What Ric said. “Yourself” is a relative term
thanks… looks like some reasonable ideas… nice bench work Ric, my layout will be a walk around in the center of the room.
I used 1x4s with a plywood deck and it was plenty strong enough for me to stand on and I’m nowhere near ‘petite’ size wize
Here’s mine…
http://www.lscdata.com/users/slatecreek/Slate%20Creek%20Tour/
http://www.lscdata.com/users/slatecreek/Slate%20Creek%20Construction%20Photos/
Probably quite heavily overbuilt… but it’ll hold me up.
Matthew (OV)
Victor Smith said:1x4's are plenty strong....I actually built a roof overhang on my home with 1x4's and was laughed at until they held the blizzard of 96 snow load with no issues.
I used 1x4s with a plywood deck and it was plenty strong enough for me to stand on and I'm nowhere near 'petite' size wize
Norm, Go for the L girder, like they say you can walk on it.
