Well, it’s finally happened – I’m getting sick of cleaning track. Also, as I add more buildings to the layout, it’s going to be harder to reach some areas of track. So… I need some battery advice.
For my Ten Wheeler, I plan to put the batteries in the tender, removable via the oil bunker. Same with any future steam locos, including the Porter conversions I have planned. There’s not enough room in my RS-3 for internal batteries, so I think I’ll put them in a gondola, covered by a fake load. That should make it easy to charge or swap out the batteries.
What type of batteries should I get? Here’s what I’d like:
Compact.
Easy to charge and maintain, and doesn’t have to be run completely dry before recharging.
No “memory” issues.
Easy to obtain.
Good run time (3-4 hours), on my layout with steep grades and tight curves. Trains are kept pretty short.
What do you suggest? Is there anything else I need to know?
