In-ko-pah RR: The Mineral Ridge Mill
You weren’t kidding about a tight spot to build this cool structure. How will the neighbors feel when that mill turns on and the dust starts flying? That guy sitting on the wall is probably thinking “there goes the neighborhood”
Your build reminds me of Boston Sand and Gravel which is a company situated within sight of North Station in Boston. It used to be rather open there then when the BIG DIG came through the 2 level highway ramps were built around the BSG. It looks funny when you drive by seeing this company jammed inbetween the highway ramps.
Keep up the good work.
Nice!
It really looks great Ray.
Ray
You are retired right?
I could never find that amount of time to spend on one building.
So I will watch you build it! :slight_smile:
Time for another progress report…
I finished installing the framing on the interior walls. (The diagonal braces will be added later, after it’s painted.) The ore chute is removable to facilitate painting:
Then I painted the interior. The timbers and framework are painted to look like aged “indoor” wood. The interior wall was painted a zinc-like gray, to simulate the appearance of the galvanized metal that will be applied to the exterior. The ore chute was painted separately, then glued in place:
I also started building the roof, which is fairly complex. This is due to the ore chute for the upper level tram:
The interior of the roof is braced with 6mm thick sheets of Sintra PVC glued flat to the underside, to prevent sagging or warping in the sun. There are also crude rafters made of the same material. More bracing will be added later:
Here are a couple shots of the interior. I’ve added some planking to create a “floor” and painted it to match the timbers and wall frames. I still have to install the tracks for the lower level tram, which will run through the building. The roof has not yet been finished nor painted:
That’s all for now, more later.
I love how you are able to pant the plastic to look like wood. Amazing…
Time for another update on this project…
I glued the corrugated metal to the sorting house, starting with the roof:
Then I did the walls:
I painted the roof, including the interior. The interior of the roof will only be minimally visible, and in shadow, so it got a really sloppy, crude paint job – something with just enough variegation to give the impression of old wood:
The exterior was painted, and the roof received some rusty streaks. I still need to do a bit more weathering of the roof, and haven’t yet weathered the sides:
Meanwhile, the main part of the mill has been sitting outside on the layout for a while. As a result, I found that the two sloped sections of roof were not sufficiently braced, and warped in the hot sun. Straightening them out without damaging the corrugated metal was a little tricky. I had to heat the underside with a torch to soften the PVC slightly, then lay it fly with a couple bricks on it. Once that was done I added some heavy bracing, and then painted the underside of each roof:
Then I weathered them with some subtle streaks and a few rusty spots:
I also weathered the peaked roof on the lowest level of the mill:
Now I’m working on the doors and windows, which are from Grandt Line. Since they need to look old and heavily weathered, I scribed some wood grain and a few small cracks into them. Then they were given a light coat of white primer. Next I painted them with a light, grayish brown latex house paint, thinned with water:
This was followed with a few very thin washes of medium brown and dark brown craft acrylics:
The final step was to give them traces of old, peeled paint. This effect was achieved by coating each piece with Testor’s enamel thinner. While this was still wet, I lightly brushed on some green, craft acrylic:
Next will be the “fun” part – cutting glass to fit all the windows.
Damm you’r good!!!
Ditto!
Looking very nice!
Are you planning on using real glass? I’ve had very good luck with clear acrylic - it looks just as good as glass and is a lot easier to cut. It doesn’t yellow at all.
Wow.
Ray, you make my layout look bad. :smiley:
Thanks for sharing your work!
Terry
Thanks guys!
Bruce, yes it will have real glass. I have some 2mm thick glass I like. It’s really not too bad. It’s just that the Grandt Line windows only give you about 1/16" overlap, which isn’t a big margin for error.
Impressive. 2mm seems pretty thick - I know what you mean about those Grandt line windows - not much slack.
Will you use glue, or mount the glass in a more prototypical manner? :wink:
I’ll use clear silicone sealant to hold the glass in place.
BTW, something I forgot to mention… some kind soul had an order of corrugated metal sent to me, anonymously, from Rainbow Ridge. However, since I’d already sheathed everything except the sorting house by that time, I decided to stick with what I’ve been using and save the Rainbow Ridge stuff for another structure.
That looks so good.
Do you have any glass cutting tips? The owner of the mill and the undertaker are complaining!
Well, glass cutting is something I’m still trying to get the hang of. I suggest using a good, carbide-tipped metal scriber instead of the usual glass cutter, if you need to be precise. And go over it several times to get a good “scratch” before trying to snap it off.
Awesome, Ray!
A labor of love.
The peeling/faded paint effect is great.
With the carbide-tipped cutters should you lube them with kerosene?
Good question – I don’t know!
