I’ve stopped work on the Princess Shilo Mine for a while, so I could get going on the Mineral Ridge Mill. The space available for this mill is very limited and challenging, and will only permit a very small mill. My goal is to create a freelance structure that is at least plausible and follows prototype practices as much as possible.
I had previously built the foundations for the mill, and the large wooden ore bin. The next step was to design the mill building. It’s a fairly complex shape, with an irregular footprint, that goes up the slope in steps. The easiest way to design the building was to build a mockup out of foam core art board.
I started with the grizzly and sorting house on top of the ore bin. Because there will be mine tracks leading to the sorting house from two different levels, I originally planned to make the sorting house a two-story structure. Here’s the first mockup, sans roof:
After seeing this in place, I didn’t like the looks of it. It was too tall and would block the view of structures that will later be added behind it. I cut it shorter, changed the shape of the roof, and added an opening in the roof where ore can be dumped from the higher of the two mine tracks.
Next I went to work on the main mill structure, starting at the level just below the ore bin. As with the sorting house, I started out making it a taller structure, then decided to cut it shorter. (When determining what will look best, it’s easier to cut off excess material than to try putting it back on.)
Anyway, here’s what I ended up with. I haven’t added roofs yet, and may not as they aren’t critical to the mockup. The next step will be working out the size and location of the doors, windows and certain other exterior details.
The actual model will be constructed using Sintra PVC board, with corrugated metal applied to the exterior. I don’t intend to model the interior, though it will have lights. I may install just enough timbers and other bits to give the impression that the structure isn’t completely hollow.
That’s all for now. Enjoy!
