Because this depot will sit so close to the “edge” of the layout, a detailed interior is a necessity! However, this is the first building I’ve made with an interior that is also visible from all four sides. Previous structures had the rear wall against a cliff, allowing me to make that wall removable. (It also cut down on the amount of exterior detailing!) The interiors could be built into a box that slides out the back of the building.
On the depot, the interior box has to be accessible from below. Not a big deal but it does complicate things a bit. For one thing, the way I make and install the windows, they extend into the building slightly. So the box has to clear the windows and avoid damaging the shades/curtains.
I built a recessed rim and spacers in the main structure. The rim creates an overlapping seal to help keep out moisture, as well as giving me something to put the screws into that will be used to secure the interior. Here’s a view from the underside:
And here’s a view from the top. I haven’t installed the spacer on the wall at right yet, because I’m debating whether or not to add a window to that wall:
Here’s the box which will contain the interior. The ceiling is removable and held in place with small screws:
Here’s a shot of the underside of the building, with the box temporarily installed. For this shot I only used two screws, instead of the six that will eventually be used:
Note that the floor of the west wing (baggage/freight area) is also removable. This room will not have interior details.
Here’s a shot looking down from the top. The second floor windows will have closed curtains, eliminating the need for detailing the second floor. Only a light will be installed there, to shine through the curtains:
As you can see, I’ve also installed the bracing for the roof of the west wing, and will soon add bracing for the main roof:
