Here’s my latest progress report… I built the removable roof for the hotel. I began by building a channel out of rectangular styrene strips and installed it on the inside of the front wall. This will be used to support the roof, and also to catch any rainwater that seeps in between the wall and the roof. A styrene “lip” on the underside of the roof will fit into this channel:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5992c/IMG_5992c.jpg)
I drilled a hole through the side walls at each end of the channel, to allow the water to drain out:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5986c/IMG_5986c.jpg)
I glued a short piece of styrene tube into each of the drainage holes. These will be painted to represent terra cotta pipes:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5984c/IMG_5984c.jpg)
The roof is made from a sheet of PVC and slopes down toward the rear of the building. Short walls were added on each side, along with some brackets, to support the angled “false roof” above the sides of the hotel:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5936c/IMG_5936c.jpg)
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5938c/IMG_5938c.jpg)
I also built some small structures such as this, to detail the roof:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5976c/IMG_5976c.jpg)
Here’s how the roof turned out. I still have to add the Spanish tiles on the angled structures on each sides:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5998c/IMG_5998c.jpg)
Here’s the underside of the roof. You can see the styrene strips at the front and rear – one fits into the channel on the front wall, the other fits over the top of the rear wall:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_6000c/IMG_6000c.jpg)
A closer view of the underside of the eaves on one side of the roof:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_6001c/IMG_6001c.jpg)
Here’s a close up of the roof installed on the building. Under the eaves there is a trim board that fits over the top of the side wall:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_6002/IMG_6002.jpg)
I also built the doors for the main entrance. I started with two doors from Grandt Line. Since they were not intended for use as double doors, I had to remove the molded doorknob hardware by carving and sanding. I glued the two doors together and built up a new door frame around them, using various sizes of rectangular styrene strip. The arched window had to be cut from sheets of styrene:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5968c/IMG_5968c.jpg)
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5971/IMG_5971.jpg)
Here the doors are test fitted into the door opening. I still have to make custom door handles:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5962/IMG_5962.jpg)
I made a louvered vent for this arch at the top of the hotel, using Evergreen styrene clapboard and styrene strips:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5985c/IMG_5985c.jpg)
And here’s how the whole thing looks so far:
(http://www.raydunakin.com/Site/IRR_Dos_Manos_Building_5_files/Media/IMG_5981c/IMG_5981c.jpg)
That’s all for now, more to come!
