Here’s another little project I’ve got going. I’ve sculpted a figure of Cris’ grandmother, who is 104 years old. This figure will be seated in the back of my rail bus, so I eliminated the lower legs in order to clear the electronics located under the rear seats.
Anyway, I decided to try making a mold of this figure, so I can cast resin copies. This will allow me to replace the figure if it ever becomes damaged or faded. I’ll also be able to make duplicates to put inside buildings or passenger cars. If this works out, I will do it with all my future figures. (I can’t do it with existing figures because they’re painted, which fills in some of the finer details.)
Here’s one of the photos I used as reference when sculpting the figure. Unfortunately i didn’t get any photos of the sculpting process:
I mounted the completed figure to a piece of 6mm Sintra PVC foam board. It is secured by a screw from underneath. Then I started adding some plasticine clay to divide the mold. It is important to use only sulfur-free clay, to prevent contaminating the silicone molding compound:
At this point I built up a box around the figure, using more of the 6mm Sintra. No glue was used – it’s all held together with #2 x 3/8" stainless steel, pan head, sheet metal screws. This way the box can be assembled and disassembled as needed:
Then I started packing in clay to fill the area which will become the second half of the mold:
I smoothed it as best as I could, then used the end of a paint brush to press small dimples into the clay. This will help to keep the two halves of the mold aligned during casting. After I shot this photo, I decided to add a strip of styrene from the arm’s elbow, down to the base of the form. This will help prevent air getting trapped in the arm, and allow the resin to get all the way into the arm and hand – I hope!
In hindsight, it might have been better to cut the arm off, and mold it as a separate piece. But for now we’ll see how this turns out.
After spraying it with mold release, I filled the upper half of the form with silicone molding compound. I use Oomoo 300, because it’s easy to use and relatively forgiving. It mixes 50/50 by volume, so you don’t need a precise scale or anything like that.
The next day, I opened two sides of the form and starting prying out the clay. I used a small screwdriver to gently dig at the clay. The clay doesn’t stick, so it pulls away from the figure pretty well:
I replaced one of the sides on the form, and removed another for better access. Then I removed the rest of the clay. There was a tiny gap under part of the figure, so I smeared a little clay into the gap to keep the silicone out from under it:
That’s as far as I’ve gotten. More later!
