When running the Bachmann Outside Frame 2-8-0 or K27 on Aristo-Craft track, derailments of the pilot wheels often occur. When I worked with Bachmann on the C-19 we spend a good deal of time on the pilot to ensure the Pilot stayed on the track. I have now gone back to the outside frame 2-8-0 and K27 to see of some of the same techniques worked. There is often a poor transition from the rail to the frog of these turnouts or a bump at the points and the pilots pick these areas and often derail. Other places where pilot derailment occurs is when the track is not level. Two improvements were applied to the older models and in operations they seem to work well. Today the only pilot derailments we had on either model were due to Acorns and I am not sure there is any solution to thest. Improvement 1: the vertical side to side play on both these models is a little restricted. by rounding the mating surfaces you can increase the freedom of movement. Improvement 2: Bachmann has improved their flange over the years. I took the older pilot wheel and increased the angle of the flange in a grinder followed by smoothing with a file. Perhaps someone else could try to duplicate this and see if they obtain the same results. One caution grinding a wheel is a one way process so some care must be applied. In the below photo the origional wheel is on the left and the reprofiled wheel is on the right. Stan Ames
