Okay Friends, I finally have some time for railroading and I started a consist of reefers/refrigerated units to be pulled by an Alco FA-1 (no B unit); they are all conversions from those Linville River boxcars as well as a couple of refrigerated units from Bachman, all painted up and worked on. Here’s the project laid out on the dining room table, although it can’t be there much longer!
Here’s the start of the undersides of the freight cars:
Here’s the problem: I am body mounting kadee couplers #1 scale to the freight cars and I want to body mount a coupler to the back end of the FA locomotive. There’s nothing but air there! Not only that, but you can see that with the back door frame and the imitation expandable air passage (I don’t know what it’s called) there’s not much room for clearance around turns.
Here’s the clearance I have on my freight cars, and I like this distance:
Here’s what I have to work with on the end of the FA (Kevin installed an onboard battery system for me and the connections you see are part of the installation), and my question is, how am I to make this work? I 'm tempted to cut off the frame and the expandable walkway, but I’m not sure if this will work or what to do after that. Has anyone done this conversion before?
Thanks!
