Why just Spring cleaning? It’s becoming more like a cleaning before each run!
Imagine if you will, a raised track embankment and well defined drainage ditches on either side … there’s a switch under that. About 30’ buried.
There’s a clue! Unfortunately that’s not a miner’s bore! Yet those are ‘tailings’ from the round tail ground squirrels that infest here. Seems my ‘cut’ is perfect for their disposal.
Several years ago I elevated the lower half of the pike to ease the grade and maintenance. To raise this half the first half must go higher…
I’ve raised one section to finalize the height and then to hang new sections as I build supports under existing structure.
Above; You can see the cleat just to the right of the Wonder bar and the 2nd section resting on it. The level is on the 1st section and is at 1% grade.
The second section above half way up, shows the transition between the old ground and elevated. I had to straddle this end and lift with one hand as I shoved that block under it.
I’m 66 and just beat lung cancer, so it was break time. I was sitting in my ponder chair catching my breath when my eyes adjusted to the light …
I had to edit the pic to see what I saw… Notice the blue rocks above and how close to where I was standing. Time to bring out my snake boots, knee highs and snake resistant.
Last May I showed you a happy couple sharing a meal…
Isn’t he cute?
Trouble with baby snakes is they haven’t learned to meter their venom yet, they tend to hang on and give you all they’ve got.
I only kill what’s under the house, so I gave it plenty of distance, zooms are fun.
I did get that end up and will build it’s supports today.
The fore ground gets rebuilt this year …
Cleaning? Were it so simple.
Happy Rails,
John
