So after some prompting from a certain LSC member, won’t mention any names (cough Bart cough) A few pictures were shared back and forth a while back, and it was of a loco begging to be bashed. This has sat on the back burner for some time awaiting parts. A while back I was in search of a Bachmann 45 tonner cab, but also during that was offered an almost complete 45 tonner, plus a few odds and end parts from a scrapped loco, so after sitting on them for a while along with a set of old Bachmann shay trucks, the time has come to do something with it. Here is a pic of the prototype, a shop built diesel using a Shay locomotive frame and trucks, and adding a 400 hp cummins diesel. it used the fuel bunker from the shay as the rear hood, even leaving the sand hoppers intact
so today I dug out the parts and put it together, I do not have a spare shay frame as the one I have will be used in future in building another shay, so I will be using the Bachmann 45 ton frame, just be adding end beams to it to resemble that of a shay. Here it is sitting together. it won’t be a big puller as one of the trucks has suffered split gear syndrome, but will work for pulling a few disconnects around, and if it strips, I will double head it with another loco
plans in the works are to scratch a new “bunker” for the second hood, and a few frame mods including building truck mounts.
