Hello-
I know this is very basic but I don’t think I have all of the information I need so I’m hoping you can help. How do I size a potentiometer to control my track voltage? I have a solid industrial power supply rated at 24VDC/5A. The plan is to run that through a voltage regulator (Digikey LT1084CT-12#PBF-ND) and then through a pot. Here’s where I get lost. I don’t know the draw range for locomotives. It seems very unlikely that it would be five amps. Using the max values I’m at 60 Watts which seems excessive. Any suggestions?
