Joe Zullo said:
Here is my question: How to properly test a live steamer on air?
Where to insert the air? Directly into the boiler where water would have been added?
Do you lubricate the cylinders? How?
What other procedures should be done?
And now back to your regularly scheduled program.
Joe, we just pressure the boiler with air, leaving the water out. Most engines can have an air line attached through the filler hole, though you may have to make an adapter to make the line fit the hole.
I use a portable tire pump that I keep in my car anyway. The air line doen’t have to be a great fit - a rubber grommet or plug will give you enough time to open the throttle and see what happens. My pump has a variety of small adaptors for footballs, air matresses, etc, and I can usually persuade one to work in the hole. (Another pair of hands can be useful.) My last test was in the back of my small SUV which has a 12V outlet and a flat surface for the rollers. Ah yes - you may need rollers so the loco can spin its wheels without going anywhere. But a Ruby can be set on blocks under each end; probably no need for rollers.
Alternatively, if the loco has a Goodall filler valve, then air can be pumped in through that, just as water would go in to fill the boiler. Or the check valve on the backhead (probably not present on a Ruby) willl usually have a pipe nozzle that you can attach a pipe onto. Auto windshield washer pipe is the preferred tubing, as it is pressure resistant.
If you plan to do it often, then make a proper adaptor to connect the air pump to a quick connect. Jason can advise.
With a new engine that has teflon o-rings or graphite tape you don’t need lubrication as long as you only do a short test. It won’t hurt to put some regular oil (not steam oil) in the cylinders when you bolt everything together, and that will help the testing. You can try to drop some oil into the steam pipe so it finds its way into the valves and cylinders.
Have fun!
