I have a loop to loop reverse loop setup for my Christmas display. The switches are set so that the train always enters and exits the loop the same way. Upon exiting the train pushes the points of the manual LGB switch to the right direction. Once the train passes the switch springs back to the entry direction. This has worked great for years but now the switches are not quite as responsive and may not spring back all the way to the entry position. Is there a way that I can add more spring tension to the switch?
cheers
timmyd
