I have the Raritan River 0-6-0 that I would like to add smoke to. Someone told me to get a generator from Aristocraft and it will go right in. True. But I also want it to work. OK, the first picture shows the space inside the boiler I have to work with.
There is a small flat spot on the bottom. Picture #2 shows an LGB generator next to the actual smokestack. They are the same size! Arrgggh! The second generator is from a Bachmann 4-6-0 that got destroyed in Hurricane Sandy. The third if the Aristocraft which says it is for SD-45, but Navin said it is the same one as in the Pacific.
Now, the question I have for the best minds at Muppet Labs is: Which one do I use and how do I install it? Thanks, Lou
