I removed the housing that has the bulb but I would like some advice on how to get the burnt bulb out of the housing. It looks like the lens has to be removed in order to get the bulb out of the housing. The question is, how to remove the lens without damaging the housing or breaking the burnt bulb?
Thank you. I will give it a try.
If the wire isn’t stiff enough you might fit an opened paperclip in with the wire to push with.
