Now that my railroad’s a “go,” I’ve been thinking about roadbed and have decided on decomposed granite which I can buy by the bag or by the truckload at a local landscape supply company. As well as roadbed I’ll use it as ground cover over the entire planter to keep out weeds. Originally I thought that if I just threw the track down on the DG, it would work OK since the area is flat and pretty tamped down. But then I got to wondering if the DG would get into the switch points? So will it? And what should I do? Maybe I ought to lay the track on some base material like Trex, even boards, just to keep it out of the DG. Yes, I know boards will rot, etc. I was just sayin…
BTW, prototypically speaking, real railroads sometimes run on the ground and not on roadbed. While on a fan trip on the Cumbres & Toltec, I was surprised that in the flats outside of Antonito, the track was barely spiked and the ties just kinda laid in the dirt.
