Mcneely has been preaching this sermon for years. Wrong on so many levels:
Quote:“The problem with charging before you put them away, is…how do you know they are stiff full when you go to use them again?”
Because lithium does not self discharge on the shelf the way Nickel does.
Quote: "Using a high-rate charger (like a Triton set to 2.5 amps) will cause some real smoke issues if you jam it twice.
Wrong again. First off, the protect pcb on the pack, and the smart chip in the properly designed charger will prevent this from happening. If a fully charged pack is presented for charge, the charge current will drop off so fast the charge will terminate very quickly.
Lithium charges differently that old style tech. Lithium charges in stages, and the primary charge function, after initial charge run up, is constant Voltage, not constant current. Setting a triton on Lithium cycle at 2.5 amps means nothing as the current drops off and terminates charge. Dont take my word for it, look it up. Best way to charge and use lithium is to charge to about 85% rated, they will last a very long time that way. This is also the best argument for a really good charger, and not the 20- 30 $ fake smart chargers that many folks use. They work, but will not avoid saturation charge, which is what will shorten the pack lifetime.
Voltage is what stresses the cells in a lithium pack, not current.
