I click the damn insert / edit embedded media button, paste the damn youtube link and it still doesn’t f ing work, wtf
can’t see the first on my machine, Flash not installed…
but for the 2nd one, I did this (remove the * and it should work for you)
[youtube]http://youtu.be/WvMl8LUzQnk[/youtube]
so I’ll try it here w/o the *
taaaa daaaa!
The easiest way I have found to do it: Under the youtube video is a “Share” button, click on that and Copy the URL that comes up. Paste that between [ youtube ] and [ /youtube ]. (just leave out the spaces that I put in the youtube tags)
nope I coppied your post , removed the * and it still doesn’t work
Looks like you “Copied” the whole page…
Little patience…we’ll get you through it.
Hit the “quote” on Cale’s post…that’ll show you the tags he used.
Use ‘Old Embed Code’ from YouTube and paste into the ‘Source’ field from the Insert Video button.
Andrew
Mark Dash said:
Now I can see why that engine would be smoking; the temp went up a bit on each try.
Now Mark, what that so hard?..
